Complete list of hoses for Jaguar X308 XJR XJ8
JCP hose list, heater and engine cooling, expansion tank bleed hoses, XJ Series from (V)812317 to (V)F59525 (X308)
I read through a number of topics and posts about replacing all heater and coolant hoses on an X308 Jaguar (and other Jaguars) as preventative maintenance Someone posted a useful list in one topic for the S-Type. I struggled to find a similar list for the X308 so here's the complete list I put together as part of my Jaguar long-term maintenance schedule. I mostly used Jaguar Classic Parts website for diagrams and part numbers. I don't have the Jaguar part number CD (yet ... it was ordered but hasn't arrived). Total I found was 19 hoses for supercharged and 14 hoses for non-supercharged. Not including metal pipes or airconditioning refrigerant hoses. If replacing all hoses, you'll need to order more parts depending on which hoses get replaced. Search for TSB 303-48 (there's a PDF link in the forum somewhere) for heater hose replacement list of additional parts (inlet manifold gaskets and throttle body gasket seem to be the most important items). You might also need valve cover gaskets and o-rings. For my XJR (2000 MY, 160,000 km in Apr 2015) I bought 16 out of the 19 hoses for replacement. Either Dayco, Gates, Eurospare (UK), URO (USA) manufacturers. Possibly one or two genuine Jaguar OE. I'll try and keep an eye on the 3 hoses I didn't replace (one small SC hose, the big octopus heater hose, one more heater hose). The logic I used was if a hose was not available from an alternative supplier (URO, Gates, etc), or difficult to find from a large supplier, then it was more likely to have a low failure rate. If it was cheap then I'd get one anyway, if expensive or difficult to find I'd leave the original one on the car for now and consider replacing in a year or two. Where I live, if the octopus hose fails, apparently I could just disconnect the heater since it's so rarely used. Most comments I found regarding a hose replacement maintenance schedule suggested replacing them at intervals of 5-6 years. The second most common comment I found seemed to be replace if leak found or hose breaks. In 15 years the only hose which failed on my Jaguar that I knew of was one of the bleed hoses from the expansion tank, about a year ago. I owned the car for the past 12 years and I don't think any hoses were replaced in the first 3 years. I have another car I bought new in 1999. After 16 years it still has all original hoses, none have leaked or failed or been replaced (but I'll replace them all now). Some questions 1. Has anyone ever had a hose fail due to age on a car less than 5 years old? Less than 10 years old? Less than 15 years old? 2. Has anyone had one of these hoses fail or leak on their X308 Jaguar? ... Octopus heater hose (#7 in list): MNC6733AE or MNE6733BA for XJR SC cars, MNC6733AC for NA XJ8 cars. ... Hose from water valve to water pump (#8 in list): MNC6742AC or MNC6742AB for XJR or XJ8 cars. ... Water hose from supercharger to intercooler (short, small hose) (#19 in list): NCC7723AA for XJR cars only. 3. How do different OEM or aftermarket hose brands rate for durability vs OE? Aside from URO, Eurospare, Dayco, Gates, I didn't find any other brands for Jaguar cars. List of hoses for Jaguar X308 XJR and XJ8 NA = Normally Aspirated XJ8 SC = Supercharged XJR PN = Part Number NF = Not Found JCP = Jaguar Classic Parts (Jaguar Heritage Parts), first price if given is from them BC = brit-car.co.uk RA = RockAuto A. http://www.jaguarclassicparts.com/uk...2-4-0-litre-v8 1. (#5 in diagram) [SC, MNC4505BC] Radiator top hose To VIN (F02261) MNC4500BC > From VIN (F02262) MNC4505BC £22.18. Not RA (was, for $3.51, URO, but no more in stock). Amazon, Dayco 71598 ($18.76!) 1. (#1 in diagram) [NA, MNC4505AD] Radiator top hose £26.84. RA URO for $7.43. 2. (#7 in diagram) [SC, MNC4519AE] Bottom water hose (not heater octopus hose but baby octopus hose) To VIN (F02261) MNC4518AB > From VIN (F02262) MNC4519AE £62.41. BC £67.09. RA URO $42.79. 2. (#3 in diagram) [NA, MNC4515AD] Bottom water hose To VIN (F02262) MNC4510AD > MNC4510AE > From VIN (F02263) MNC4515AD £27.90. RA URO $32.79. http://www.jaguarclassicparts.com/il...es/se6347c.jpg B. http://www.jaguarclassicparts.com/uk...eed-and-return 3. (#1 in diagram) [SC or NA or both, not clear. EGR?] Heater feed hose From VIN (F00035) +EGR NNE3947BA £22.83. 3. (#1 in diagram) [SC, AJ87634] Heater feed hose To VIN (F07814) NCC3945AC > From VIN (F07815) AJ87634 £7.37. RA $5.35 URO (need to search by PN). Amazon (says doesn't fit XJR) $12.87. BC £7.92 Jaguar. 3. (#1 in diagram) [NA, NCA3945CD] Heater feed hose Other Option NCA3945CD £10.51 4. (#2 in diagram) [SC, NA, NNE3946CA] Heater return hose NNE3946CA £10.51. Amazon $15.49 URO. RA $8.40. BC £4.71 Eurospare, £11.30 Jaguar. FCPEuro $11. 5. (#7 in diagram) [SC, NA, AJ83970] Feed hose throttle, From Engine (0108130000) AJ83970 £4.84. RA $4.00 URO (need to search by PN). Amazon x$9.80 URO. BC £5.20 Jaguar. FCPEuro $5.29 URO. 6. (#9 in diagram) [SC, NA, NCA3976AD] Hose (what name?) To VIN (853935) NCA3976AD £8.86 ... RA $6.66 URO, Amazon (says doesn't fit XJR) $11.07, BC £9.52 Jaguar, FCPEuro $9 URO. 6. (#9 in diagram) [SC, NA, NNE3976CA] From VIN (853936) NNE3976CA £28.22. RA $5.88, Amazon (says doesn't fit XJR) $10.59, BC £30.34 Jaguar, FCPEuro no. http://www.jaguarclassicparts.com/il...es/sk6370a.jpg (#4 in diagram) (Not ordered, is metal pipe?) [SC, NA, NCA3905BC] Heater feed pipe NCA3905BC. Not found JCP, RA, Amazon, BC, FCPEuro. $70 from terrysjag.com. (#5 in diagram) (Not ordered, is metal pipe?) [SC, NA, AJ83928] Heater feed pipe From Engine (0108130000) AJ83928. BC £27.75 Jaguar. $40 terrysjag.com. Not found Amazon, RA, FCPEuro. C. http://www.jaguarclassicparts.com/uk...d-hoses-petrol Octopus hose PNs different for XJ8 and XJR according to JCP. But same hose used for either according to some other sources. 7. (#6 in diagram) (Not ordered) [SC, MNC6733AE] Heater hose with valves (Octopus hose?) [or W0133-1656883 Eurospare PN?] MNE6733BA > MNC6733AE £108.26. BC £116.38 Jaguar, £72.75 Eurospare. Amazon $179. Not RA. Gaudin $186.46. Dealer UAE $354. 7. (#6 in diagram) [NA, MNC6733AC]. Heater hose. Not BC. Not RA. Not Gaudin. 8. (#7 in diagram) (Not ordered) [SC, NA, MNC6742AC] Hose water valve to water pump To VIN (F03079) MNC6742AB > From VIN (F03080) MNC6742AC £33.87. BC £36.41 Jaguar. Not RA. Not Amazon. Dealer UAE $98. 9. (#8 in diagram) [SC, NA, MNC6721AB] Hose water pump to heater To VIN (F03079) MNC6721AA > From VIN (F03080) MNC6721AB £6.47. BC £6.96 Jaguar. FCPEuro URO $11. Amazon URO $13.83. Not RA. 10. (#9 in diagram) [SC, NA, MNC6722AB] Hose heater to water valve To VIN (F03079) MNC6722AA > From VIN (F03080) MNC6722AB £5.96. RA URO $4.89. Amazon $10.94 URO. FCPEuro $6.99 URO. BC £6.41 Jaguar. RA lists MNA6722AB under XJR but seems to be incorrect, find correct one by searching for MNC6722AB (C not A). http://www.jaguarclassicparts.com/il...es/se6350a.jpg D. http://www.jaguarclassicparts.com/uk...8-supercharged D. http://www.jaguarclassicparts.com/uk...t-supercharged 11. (#6 in first diagram) [SC, AJ88713] Hose (Thermostat Bypass Hose, Thermostat To Coolant Inlet Hose, thermostat housing to coolant inlet) SC To VIN (878717) NCC2238AC > From VIN (F00035) AJ82569 > From VIN (F00103) AJ88713. URO available from Amazon. 11. (#8 in second diagram) [NA, AJ85313] NA not SC Bypass hose heater and air conditioning To VIN (F00102) NCA2213AC > From VIN (F00103) To VIN (F35707) AJ85313 £2.36 http://www.jaguarclassicparts.com/il...es/sb6382b.jpg http://www.jaguarclassicparts.com/il...es/tb6138a.jpg E. http://www.jaguarclassicparts.com/uk...ecovery-bottle Thin bleeder hoses, need special tool to remove and fit. Tool might be fixed to one of the hoses on the car, see these topics ... https://www.jaguarforums.com/forum/x...servoir-58518/ https://www.jaguarforums.com/forum/x...fitting-65174/ 12. (#4 in diagram) [SC, NA, MNC4468AD] Expansion tank to header tank hose. To VIN (820501) MNC4468AC > + From VIN (820502) MNC4468AD £14.58 13. (#6 in diagram) [SC, MNC4582BD] Bleed hose expansion tank to ??? SC To VIN (820501) MNC4582BA > From VIN (820502) To VIN (F45010) MNC4582BC £8.16 > From VIN (F45011) MNC4582BD £11.92 13. (#6 in diagram) [NA, MNC4582AC] NA not SC To VIN (820501) MNC4582AB > From VIN (820502) MNC4582AC £18.30 14. (#7 in diagram) [SC, MNC4583CB] Bleed hose expansion tank to ??? SC To VIN (820501) MNC4583CA > From VIN (820502) MNC4583CB £18.30 14. (#7 in diagram) [NA, MNC4583AC] NA not SC To VIN (820501) MNC4583AB > From VIN (820502) MNC4583AC £18.30 http://www.jaguarclassicparts.com/il...es/se6349b.jpg Supercharged vehicles only F. http://www.jaguarclassicparts.com/uk...p-supercharger 15. (#4 in diagram) [SC, MNC8236AB] Outlet hose To VIN (F02261) MNC8235AA > From VIN (F02262) MNC8235AB > MNC8236AB. BC £16.79 Jaguar, RA $15.21. 16. (#8 in diagram) [SC, MNC8244AC] Inlet hose To VIN (F02261) MNC8243AA > From VIN (F02262) MNC8243AB > MNC8244AC 17. (#18 in diagram, from header tank) [SC, MNC4565AB] Bleed pipe header tank quick fit MNC4565AB £23.25. BC £12.66 Eurospare, £24.99 Jaguar. Not RA or Amazon. Dealer Dubai $75 (Jaguar). 18. (#18 in diagram, from radiator) [SC, MNC4564AB] Bleed pipe radiator quick fit MNC4564AB £24.22. BC £13.61 Eurospare, £26.04 Jaguar. Dealer Dubai $75 (Jaguar). Note that in diagram there are two different hoses marked as #18 joined together (as far as I know from comparing diagram to what's under my hood/bonnet). http://www.jaguarclassicparts.com/il...es/se6348a.jpg G. http://www.jaguarclassicparts.com/uk...8-supercharged 19. (#8 in diagram) (Not ordered) [SC, NCC7723AA] Water hose supercharger to intercooler NCC7723AA. BC £23.04. RA URO $19.81, Amazon $22.22. Short small hose, seems expensive for what it is. http://www.jaguarclassicparts.com/il...es/sb6379a.jpg Other replacements to consider or do at the same time as hoses Upgrade thermostat tower if NA and not already done. Replace thermostat. ... [SC, NA] Thermostat AJ81328: SC Thermostat: engine AJ81328, Other Option AJ82600. NA Thermostat: engine AJ86484 > AJ85874 > AJ81328, Other Option AJ82600 Replace expansion tank cap (radiator cap, pressure cap). ... [SC, NA] Expansion tank cap (radiator cap, pressure cap) 1.0 bar MJA4440BA Replace water pump every second time hoses replaced. Or every 10-15 years. Check coolant expansion tank. Consider replacement after 10-15 years. Or is failure so rare don't worry unless it fails? ... JCP Expansion tank + To VIN (F52090) MNC4400AB, From VIN (F52091) MNC4400AC £131.03, MNC4400AC, [$130+] Ebay ... ... http://www.uroparts.com/uro/inventory/show/9460 ... ... [£140.86, Genuine] http://www.brit-car.co.uk/search.php?xSearch=MNC4400AC ... JCP Header tank MNC4460AC £203.96 No URO part. Not the same as expansion tank, fails much more rarely than expansion tank, don't replace unless failure. ... ... [£219.26, Genuine] http://www.brit-car.co.uk/search.php?xSearch=MNC4460AC ... ... [$297.75, Genuine] http://www.gaudinjaguarparts.com/oe-jaguar/mnc4460ac Final question Did I miss anything? |
A box of Jaguar hoses
2 Attachment(s)
A couple of pictures of what a box full of hoses looks like ...
All hoses have been fitted. Hose clips were reused but got a low coolant warning because one of them wasn't tight enough, so all the supercharger hose clips were replaced with the screw-tighten type, new ones. Left the other reused hose clips on hoses. So far no more low coolant warning.
Originally Posted by Auspuff
(Post 1238962)
B. http://www.jaguarclassicparts.com/uk/jaguar-xj-x308-parts/air-conditioning-heating-ventilation/pipes-and-hoses/heater-pipes-feed-and-return
The mechanic replaced these hoses without removing inlet manifold. He did remove the supercharger outlet duct on top of the motor though but didn't replace any gaskets. So now I have some spare gaskets and seals if anyone is in Dubai and wants to buy them cheap. Not all the ones from the Jaguar list, some of them were expensive or difficult to find so I didn't bother.
(Post 1238962)
A. http://www.jaguarclassicparts.com/uk/jaguar-xj-x308-parts/engine-cooling-system/radiator-and-hoses/radiator-hoses-3-2-4-0-litre-v8
1. (#5 in diagram) [SC, MNC4505BC] Radiator top hose To VIN (F02261) MNC4500BC > From VIN (F02262) MNC4505BC £22.18. Not RA (was, for $3.51, URO, but no more in stock). Amazon, Dayco 71598 ($18.76!) Amazon US and UK sites both have a listing for URO equivalent. I'll update this when I get a new hose to compare again. |
A nice helpful post, did your guy change the hoses under the supercharger, we've got various companies in the U.K. that supply silicon upgrades, and they're fit and forget. The octy hose generally fails at connections not the hose itself. The quality of hoses on these cars really impressed me the only one I see that always needs changing is the elbow running from the water pump, the bulge hose!
Originally Posted by Sean B
(Post 1268276)
Only ones he didn't change were: a couple of bleed hoses I changed last year (one failed at the connection to overflow tank), the octopus hose (price scared me away from buying it) a small elbow hose on the supercharger duct or manifold or something the upper radiator hose (was incorrect fit) one more I hadn't supplied (I forget why)
(Post 1268276)
(Post 1268276)
(Post 1268276)
Yes, I think the old hoses still looked in pretty good shape ... to my very untrained eye. |
Knock on wood, all of my hoses were in great shape when replaced except for the stubby from the NA tst tower to the crossover (bulging); the upper radiator blew off (it was new) when ai temp dropped to zero degrees two winters ago (radiator inlet tube contraction); overflow tube when I screwed up and used it as a handrest.
I have replaced all but the heater hoses and the octopus. Avery useful post, thanks. |
I have a small leak in one or two of the main heater hoses in my 2002 XJR (101,500 miles) and I see how buried into the engine they appear to hide and I just wonder how many other things need to come out first to get to them, especially to the top end connections. Scares me just to think about it. I just wonder what an independent shop's labor would be to change those hoses because I'm not really looking forward to that kind of pain. Or, it isn't really that bad?
OK, if somebody reading this post has actually replaced the 2 main heater hoses on the X308 XJR, could you please share some of the highlights, or perhaps a "better-after-doing-it" way to go about? I would really like to do it myself, but it looks very tough. Not only that, but now I have had a shop look at it and he agreed that it will be a tough, at least a whole day job, somewhere over $1K. That's a lot of money when the parts (hoses) can be purchased for about $150.00. Some advice, tips, or word of "it's not really as bad as it looks" would be welcome...
Thank you. Cheers, |
I think there are many threads on replacing the heater hoses. Even some Youtubes. Do a Google search. minimally, you will need to remove the intake manifold and S/C.
Originally Posted by Jhartz
(Post 1891117)
| All times are GMT -5. The time now is 04:03 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
