Compression Gauge recommendation?
Old Jul 20, 2011 | 10:45 AM
ka1thm's Avatar
Default Compression Gauge recommendation?
I am having problems finding a compression gauge to use that has an extended pressure tube to reach down into the spark plug opening. Can anyone suggest what they use? The ones I have seen have a short adapter and then a flexible hose, which I didn't believe could be used.
Any thoughts?
Thnak you very much!
<<<Mathew>>>
Old Jul 20, 2011 | 01:43 PM
test point's Avatar
Mine is just a standard pressure tester. Tighten the adapter just a bit by turning the rubber tube. The seal is via the 'O' ring on mine, not by being tight in the plug hole.
Poet
Feb 7, 2025 02:18 PM
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
jagtoes
Apr 22, 2016 07:37 AM
vwbusbits
Oct 13, 2015 03:43 AM
