Compression test issues
Old Sep 2, 2022 | 03:17 PM
Zlobby's Avatar
Default Compression test issues
I did a compression test on my 2003 XJR and got the following readings, but experienced an issue when I get to cylinder 8.
fuel pump relays pulled, warm engine, throttle body open
1 - 95psi
2 - 100psi
3 - 145 psi
4 - 145 psi
5 - 120 psi
6 - 95 psi
7 - 95 psi
8 - when i went to go crank the car, rather than the can making a sound of a cranking engine, it just made a constant whirring sound rather than the cranking sound.
Not sure what happened that is causing this, either way not super happy with my figures. Should I chalk it up to a toast engine?
Old Sep 3, 2022 | 10:02 AM
Quadcammer's Avatar
Thats not a good sign. I had similar on my bmw race car and it turned out to be a burned exhaust valve so i had zero compression in that cylinder
Old Sep 3, 2022 | 10:08 AM
xalty's Avatar
relative comp test with an amp clamp would have saved time
put a camera in #8 find out what happened somebody probably overheated the **** out of it and dropped a valve seat
Old Sep 3, 2022 | 11:00 PM
M. Stojanovic's Avatar
Originally Posted by Linas Zymantas
...8 - when i went to go crank the car, rather than the can making a sound of a cranking engine, it just made a constant whirring sound rather than the cranking sound.
Looks like you either exhausted the battery by the time you came to No. 8, or maybe your starter motor got "tired" from too much cranking. Recharge the battery and try again later.
Old Sep 4, 2022 | 07:04 AM
Quadcammer's Avatar
A dying battery would give slow cranking with plugs out or just click. The whirring is the sound of the motor spinning over without building compression
MaxTorq
Jul 12, 2022 03:08 PM
cyber3d
Jun 28, 2015 09:06 PM
Mendo XK
Nov 6, 2012 11:03 PM
SeamlessAutomotive
Jul 14, 2012 05:50 AM
