"Coolant is low"
Old Mar 3, 2015 | 07:04 PM
  #41
Jhartz's Avatar
Seriously? Duck Duck Go is your friend!
Old Mar 3, 2015 | 07:10 PM
  #42
Muti007's Avatar
Seriously, Duck Duck Go is your answer? I dont understand why you so consistently answer questions with non-answers. Im new here, just looking for some help. In return, Im doing my best to also share everything I learn along the way. Why give a noob a hard time for no apparent reason? I found the site, but am still a little unsure which hose I should be looking for for the bottom radiator hose. If Ive offended you somehow since I joined up here, please, let me know. TIA
Old Mar 3, 2015 | 07:35 PM
  #43
test point's Avatar
I just spent 20 minutes searching for a lower hose for a '99 XJR. Looked at Advance, O'Rilley, AutoZone, SNG Barrett, eBay, Amazon and a global search on the WWW. No lower hose available except one used on eBay.
OK, I guess that you are going to have to scrap your car.
You have, I think, a AJ26 engine used in the '99 XJR.
I would suggest that you give a call to SNG Barrett, a sponsor of this forum, or Coventry West which do a lot of 'out of the box' parts supply.
Old Mar 3, 2015 | 07:38 PM
  #44
Muti007's Avatar
Thanks, thats what Ive been finding as well. Obviously the car is a keeper, but finding that hose is a bit tougher than most. Even Welsh lists multiple hoses that seem to be the right one but different from one another. A cross check with other sites shows them as being the wrong hoses too.
Old Mar 3, 2015 | 07:55 PM
  #45
test point's Avatar
A call to either of the above will resolve the issue. Please let us know.
Old Mar 4, 2015 | 05:55 AM
  #46
Muti007's Avatar
Hey gang, does anyone know if perhaps it is the infamous octopus hose Ive heard about that I may need?
Old Mar 4, 2015 | 07:39 AM
  #47
Muti007's Avatar
Spoke to Scott at Coventry West and he confirmed it is indeed the octopus hose you need for the lower radiator if anyone needed that info. Their price is $120 + shipping. OE# MNC4519AE. Hope this helps someone down the road
Old Mar 4, 2015 | 09:13 AM
  #48
m1eckler's Avatar
Originally Posted by Muti007
Yep, all gauge and dash lights are in good working order. Really curious as to what you were thinking
Hey Multi-
I had an experience when I first bought a car. I had that same error message come up when the coolant wasn't low. But the car was new to mew and it was on "the list". Some other things that were on the list were the dash lights, some were out.
So I remover the cluster and replaced the bulbs and never got that error message again.
I'm wondering what I may have moved or benefited from unplugging that harness and plugging it back in.
There are two ground points back there as well. I wonder if a low voltage problem could be occurring from a bad ground…?
I'm sorry if you've already answered this question somewhere else in the thread. But, have you done a hard reset yet?
Thanks, sorry if this has already been covered.
-Mitch
Old Mar 4, 2015 | 09:14 AM
  #49
m1eckler's Avatar
Never mind! should've skipped right to the end.
Old Mar 4, 2015 | 09:22 AM
  #50
Muti007's Avatar
Thanks for sharing that Mitch, thats very interesting. I did try the hard reset early on, but at this point Ive tracked down the leak. Thankfully its still a small leak, but Ive already ordered a new water pump, thermostat, thermostat gasket, upper and lower coolant hoses. Once all the parts are here Ill have an indy install them. Until then Ill just keep a close eye on the coolant
Old Mar 4, 2015 | 09:56 AM
  #51
Jhartz's Avatar
Sometimes the float in the reservoir sticks: a small stick can loosen it up. Happens because once upon a time (all good stories start that way) POs mixed coolants between green and Dexcool. A sticking float will give you a low coolant warning.
Separate issue: Google can help you find parts: MOTORCARSLTD.com has lower radiator hoses available:
RADIATOR HOSE
RADIATOR HOSE
(0 reviews)
RADIATOR HOSE
Position: Lower
SKU: MNC4515AD
$79.30
I like Duckduckgo because they don't track you.
PEACE
Old Mar 4, 2015 | 11:09 AM
  #52
Muti007's Avatar
RADIATOR HOSE
RADIATOR HOSE
(0 reviews)
RADIATOR HOSE
Position: Lower
SKU: MNC4515AD
$79.30
PEACE
Thanks Jim. ID actually never heard of Duckduckgo so I had no idea what it was you were trying to say. I found the lower hose on Ebay, new and OEM, for $55 shipped
Old Mar 4, 2015 | 12:08 PM
  #53
ant1830's Avatar
Awhile ago I got the "COOLANT IS LOW" message. When I unscrewed the cap I also heard the 'gulp' mentioned. The coolant level was visibly low. I topped it up and have not had any warning since. I have checked it ocassionally and it appears to be holding the same level. However, I still hear the 'gulp' every time I check it. I can find no sign of leakage. There may be a miniscule leak somewhere in the system.
Old Mar 4, 2015 | 12:15 PM
  #54
Muti007's Avatar
How long ago/how many miles ago was that? If youre hearing the gulp and youve seen it low, youre leaking somewhere. Most of the time I got the message, I wasnt visibly low, but I was low enough times for me to be concerned. So Im throwing a whole WP kit at the problem as I can see thats where the leak is coming from. Id suggest you have your car pressure tested to see where/why youre running low occasionally. It seems to me, unattended leaks are probably one of the very top reasons these cars go to hell. Dont leave it alone and hope for the best. Parts are cheap a new engine is not
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
04Xjrsteve
May 7, 2019 04:06 PM
vwbusbits
Oct 13, 2015 03:43 AM
