Coolant reservoir leaking...
Old May 8, 2013 | 06:43 AM
princemarko's Avatar
Default Coolant reservoir leaking...
Does it need to be fully swapped out? or is it repairable? Could it be that sensor?
Old May 8, 2013 | 08:44 AM
RJ237's Avatar
The sensor is not a source of leaks. While some have patched it, I think you will find the plastic cooling system parts have become brittle with age and heating cycles. Considering the risk of severe damage due to overheating these engines it would be my choice to replace it.
Old May 8, 2013 | 10:29 AM
dsnyder586's Avatar
Replace. Last thing you want is an 85 mph reservoir burst and overheat.
On a side note, I purchased a coolant pressure tester this week for my fleet (family of 6 drivers) and it has already paid for itself with the first use. (didn't have to hunt and peck for the leak it showed up as soon as I added pressure) If you do not have one, spend a few bucks on it- well worth the $.
Old May 17, 2013 | 05:49 PM
Sensor was the source of the leak... Replaced the whole tank
Old May 17, 2013 | 07:40 PM
sparkenzap's Avatar
Well, the well that the sensor clips into may have been leaking, but the sensor itself is external to the tank
Old May 18, 2013 | 02:29 AM
QuadManiac's Avatar
Yep - BTW, Gus has a good write-up on the sensor on his website.
Poet
Feb 7, 2025 02:18 PM
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
