Damaged radiator
Old Jul 13, 2020 | 12:36 PM
Henkez's Avatar
Default Damaged radiator
I unfortunately damaged the radiator on my Xjr. Do you think I can still use it ?
Old Jul 13, 2020 | 03:54 PM
avern1's Avatar
Not sure how you mashed that up, but i would bet a water pump was involved. For the amount of fin damage the decrease in heat transfer would not amount to much. If it isn't leaking under pressure don't worry about it, you should be fine.
Old Jul 13, 2020 | 10:12 PM
M. Stojanovic's Avatar
You can straighten the fins back up using a small screwdriver (and a lot of patience).
Old Jul 14, 2020 | 02:30 AM
RA110623's Avatar
Banned
I have same problem but less than that . if no leaks then it's fine
XK Owen
Jul 3, 2020 09:42 AM
new mexico
Jun 6, 2017 03:35 PM
kenbowen
Mar 30, 2016 09:09 AM
andyXJR
Sep 29, 2015 04:29 PM
chrisc923
May 21, 2014 07:04 PM
