Doing Timing Chains & Tensioners - Are these the correct parts ?
Old Oct 28, 2012 | 05:12 AM
nurquhar's Avatar
Question Doing Timing Chains & Tensioners - Are these the correct parts ?
I am in the middle of doing my timing chains etc and I am at the point of re-assembly with the new parts. I am doing the primary and secondary.
Now having carefully recorded with my marker pen and camera which parts came from where and looking at the new parts I have BritishParts I wondering if they are correct.
Specificaly the straight primary guides have a slot at one end and a hole at the other. The hole should be at the bottom through which a bolt goes to retain them. The slot goes over the pin.
Now on the new parts the holes and slots are at opposite ends ??? Assuming the lip on the guides should be at the rear as per the originals.
Here is photo of the old parts in place before they were removed :
Here are the new on old parts laid out next to each other, new parts are on the right :
Old Oct 28, 2012 | 07:32 AM
Sean B's Avatar
yes they're the right parts here's a picture of a full change out of timing parts I did. Hope it helps you out - when I started fixing these engines I would have killed for this
Attached Thumbnails Doing Timing Chains & Tensioners - Are these the correct parts ?-dscf5565.jpg
Old Oct 28, 2012 | 07:57 AM
nurquhar's Avatar
Dear Sean
Thanks again.
So to confirm it for sure, the bolt now goes through the elongated hole and the top pin through the round hole ?
My parts look the same as your pic and indeed those supplied NE Jaguar. eg : Jaguar V8 Timing Chain Kit - Detailed item view - Jaguar Spares Northeast
xjrjag
Nov 27, 2025 09:16 AM
Bcrary3
Sep 12, 2015 08:43 AM
David Mason
Sep 3, 2015 03:17 AM
Bcrary3
Aug 31, 2015 11:29 AM
souldoubt
Aug 25, 2015 08:15 PM
