driver seat position when locking doors via keyfob
Old Dec 30, 2011 | 05:09 PM
domer94's Avatar
Default driver seat position when locking doors via keyfob
ok , so when i lock the doors via keyfob, i get back to the car and the driver seat back is all the way reclined. i have reset the memory a couple of times. is something else afoot here?
Old Dec 30, 2011 | 05:32 PM
Sean B's Avatar
Some mention of the symptoms TSB's and fix here.
https://www.jaguarforums.com/forum/x...ry-fobs-10433/
Hope this helps
Old Dec 30, 2011 | 08:39 PM
domer94's Avatar
thanks , i read on the subject thoroughly, however im not clear on one factor. my seat adjustments all function well, the memory settings seem to "take" as i hear the audible chime and see the light go on and off. its only when i lock the doors through the fob. i will check the wiring connections as they suggest, if that doesnt do it, would it definitly be a seat module?
Old Dec 30, 2011 | 11:23 PM
TehNam's Avatar
I have the exact same issue. Will be watching this thread...
Old Dec 31, 2011 | 01:04 PM
SuperSport's Avatar
Have you programmed your FOB for the current settings? After setting the memory on the door, within 2 seconds, press a button on your FOB until you hear another ding. That sets your FOB to the setting you just saved. Each FOB can be set to a different Memory if you prefer.
This way, when you enter your car with YOUR fob, it sets everything to YOU. Your wife can set her own settings on MEM 2 and HER fob. (That is IF you let her drive it)
99xk8guy
Sep 29, 2025 10:51 PM
mbergen
Oct 23, 2019 10:26 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Dallas XK8
Sep 3, 2015 12:17 PM
dcvickers
Sep 2, 2015 06:14 PM
