ECM Reset Proceedures
Old Sep 29, 2017 | 10:10 AM
LeLimoMan's Avatar
Default ECM Reset Proceedures "Hard Reset"
Hello Everyone! Been awhile since I've been on the forum.
At one point I had the correct procedure to do a hard ECM reset (involving disconnecting the battery and grounding leads). Unfortunately, I can't find the printout I did and can't find the link I used here.
Can anyone assist in directing with to the write up or link?
Thanks for the help
Old Sep 29, 2017 | 11:06 AM
RJ237's Avatar
All you need to do is disconnect the negative cable from the battery and touch it to the positive post for a few seconds. Anything beyond that is overkill.
