Engine won't start with a spare key
Old Dec 5, 2011 | 12:28 PM
mbkumar's Avatar
Default Engine won't start with a spare key
Hello All,
Recently I lost keys to my 98 Jag XJ8. The previous owner gave me a spare key which I never tested. With the 2nd key, I am able to open the doors. When I put it in the ignition, the steering wheel comes down, indicator lights turn on .... ,but the engine won't start.
The previous owner said that the key worked for him. (But he is not sure). He got a pair of keys from different sources when he lost his keys.
Do I need to do anything to get the key working (as far as security is concerned)? Or do I need to tow the car to dealer to get the key programmed?
Any help is appreciated.
Bharat
Old Dec 5, 2011 | 03:09 PM
flay's Avatar
You need to go with the car to the dealer,to programm your key vith the computer plugged in;I also need this service,for the second key, but still have one original.
Old Dec 6, 2011 | 12:04 AM
jchavez76's Avatar
Don't know if this helps you, but, here goes;
I locked my only key and remote in the trunk on thanksgiving. I had new two new keys cut by VIN at my local Jag dealer. They would not start the car, but, my plan was to open the trunk and then program the keys. The keys cost me $80 US each.
I work at an independent shop and with my Autologic scan tool, I programmed the keys succesfully. It took about 5 minutes. My point is that an independent shop can do the job as well. Maybe someone can give you a local refferal for your car. Shop around and maybe you can get it done faster and at a lower cost than the dealer.
I gave my wife a key and I have one at home in case of another brain fart.
I remember that when you program the new keys, you need to have all keys present. You program all old and new keys during the sequence. All keys not present are disabled. The previous owner of your car may have bought the replacement keys you mentioned and not programmed the key he gave you because he didn't have it at the time. Make sense?
Good luck,
Joe
Old Dec 6, 2011 | 10:18 AM
mbkumar's Avatar
Thanks for the replies guys. I contacted one locksmith, who was not able to program the key. He said it is the 2nd jag he couldn't work with. I think its a trip to dealer. Hmm...
Old Dec 6, 2011 | 11:06 AM
Sean B's Avatar
only way is thru the Jaguar IDS system - the car security module needs to learn the key. A trip to the nearest dealer is in your future.
1964Daimler
Sep 2, 2015 11:41 PM
Rusty1952
Sep 1, 2015 05:45 AM
201motels
Aug 30, 2015 08:03 PM
Drew2006
Aug 28, 2015 04:22 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
