front weel bearing..?
Old May 21, 2009 | 03:51 PM
chupacabra's Avatar
Default front weel bearing..?
hi everyone... I was wondering if theres any way of changing the bearing without the special tool ? and are there any other "surprises" like special toll or is it the only problem?
and can I loose the wheel if it mooves a little ( when i lifted the car I tryed to moove the weel, it mooves a little, could see the abs ring mooving) ofcourse there is a sound coming from the bearing when driving but its not that loud ( a bad bearing sound)
Old May 21, 2009 | 04:29 PM
wazari's Avatar
There is more than one special tool for this job. Which tool were you referring to? The rotor nut socket is a must have. With the tools and hydralic press, the job is pretty straight forward.
I would worry about the bearing locking up before losing the wheel.
Old May 21, 2009 | 04:35 PM
ken@britishparts.com's Avatar
As I understand it, you will still have to press the old bearing out and then press the hub back in to reassemble. You may want to wait for a second opinion confirming this to make sure I'm correct. You do need the special tool. We have them $150.
You don't want to run too long on a bad bearing. You can damage the hub and the housing.
Old May 22, 2009 | 12:10 PM
chupacabra's Avatar
I have allready ordered the bearing, I have to whait one week for it to arrive so I wonder if it will last for one week driving intown speeds... I have changed (not myself) other bearing before and it sounded really bad (before change) when the car was driven, but this one is pretty silent..... yea.... guess i'll take it to the mechanic and let him handle it, hopefully this bearing will last for the week and if not I will tell you how does it feel when it brakes up
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
johndahlheimer
Sep 16, 2015 05:44 PM
Don R
Sep 14, 2015 12:34 PM
