Fuel Filter
Old Dec 9, 2016 | 01:45 PM
Dicque's Avatar
Default Fuel Filter
Hello all,
tried to replace fuel filter 02 VDP x308 gas came pouring out of connection left side.
Placed a pan underneath the flow waited several min. but it would not stop.
confused.
Battery was disconnected. Help!
Old Dec 9, 2016 | 05:14 PM
Hello,
Someone will be along soon to direct you to the correct section where you can find help for that! But how Annoying!
Old Dec 9, 2016 | 06:37 PM
Dicque,
You've already posted an Intro in August 2015:
https://www.jaguarforums.com/forum/n...-parts-148630/
I've moved your question from General Tech Help to X308 forum. This is the place to post technical questions about your model.
Old Dec 12, 2016 | 07:10 AM
dwgates's Avatar
Default fast swap...
People say pull the fuse for the pump and run the car until it dies to keep this from happening. It may just be a syphoning sort of thing as I pulled the fuse and still had fuel spillage. I did the swap as quickly as I could and tried to collect as much fuels as possible before it soaked into my blacktop. Messy job for sure...
