Fuel Injectors which to buy?
Old Jan 8, 2026 | 11:29 PM
Ant305's Avatar
Default Fuel Injectors which to buy?
I’m looking to replace the fuel injectors in hopes that it will fix a cylinder 6 misfire that im having but all the injectors I’m finding online seem to be different.
$236 PartsGeek (Genuine) (Singles)
$134PartsGeek (Autoparts Premium 8 pack)
$230-280DensoFuel (8pack)
Old Jan 10, 2026 | 10:47 AM
hispeed42's Avatar
That's a lot of work only to find out that it's not the fuel injector(s).
Old Jan 10, 2026 | 10:51 AM
Ant305's Avatar
Well I’ve gone through just about everything else. My last options are fuel injectors or fuel pump.
If you go to my previous thread, I talked about how I was only getting 19-21PSI of fuel pressure and it was also slowly going down.
I purchased fuel pumps/strainers and if that doesn’t fix it, I will be purchasing the injectors. But I just wanted to get an opinion on which Injectors were best.
Old Jan 10, 2026 | 10:56 AM
hispeed42's Avatar
I replied to your other thread before seeing this one.
Old Jan 12, 2026 | 12:56 PM
David N. Warner's Avatar
That fuel pressure it too low. (I think it's about 30-40 lbs. depending if the vacuum line is attached to the regular or not) You might start by replacing the fuel pressure regulator before fooling with the injectors.
Old Jan 13, 2026 | 12:32 PM
hispeed42's Avatar
Those readings were taken with key on engine off. Ant got 40 with the engine running.
Dustin Moorman
Jan 10, 2023 08:42 PM
santacruz11
Aug 17, 2022 07:25 PM
new mexico
Jul 6, 2017 04:28 PM
Ixlr8
Sep 29, 2010 02:11 AM
