Gearbox problem - 1998 XJR
Old Feb 2, 2015 | 06:58 AM
Niklas Xeronen's Avatar
Default Gearbox problem - 1998 XJR
Hi! I have an issue with my gearbox... today when hade the car on idle a couple of minuets, later when I was about to drive it was impossible to get the stick in D.. it was stuck in P. I had tried to hit the breaks a couple of times and to restart the car but the problem remains. What to do?
Old Feb 2, 2015 | 07:58 AM
bdboyle's Avatar
First thing I'd check is the brake switch; when you step on the brake, do you hear a 'click' from the shift lever area? It's part of the nannny-state-mandated 'You have to step on the brake before we'll let you move the tranny out of park' circuit.
Alternatively, if your switch doesn't work, there is a procedure in the owner's manual that tells you how to manually release the lever: requires that you remove the star-headed fitting at the upper left hand side of the face of the J gate, and gently use your spare key, I believe, to release the lock.
Forcedair1
Sep 8, 2025 01:57 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
XJsc-guy
Sep 25, 2015 11:09 AM
arnoldmilk
Sep 3, 2015 07:42 PM
pnwrs2000
Sep 3, 2015 11:55 AM
