Got raped at the dealership...
Old Sep 23, 2010 | 09:42 AM
princemarko's Avatar
Originally Posted by sparkenzap
"Id love to find a manual. "
Does that imply you do not consider JTIS and /or Alldata to be a suitable manual? Or do you not know about them?
If you are referring to the lack of info in thiose sources, I feel your pain.
I looked at JTIS, and its not comprehensive enough. I want the shop manual that the dealerships have.
Old Sep 23, 2010 | 02:45 PM
Sean B's Avatar
You've got to be brave, and go for it, (take a peek at the work I've done in my garage on here without a manual) look at how everything goes together, note torques when taking it down, spend time doing this first, and lots of pictures. You build up a good knowledge and confidence in working on them very quickly. A good set of metrics and torx helps, and hose pinch pliers.
JTIS get you somewhere on some things, you've to search around the area you plan to work on first, on the disc.
Old Sep 23, 2010 | 03:23 PM
Barry (NJ)'s Avatar
Does anyone know if this one is any good?
http://cgi.ebay.com/ebaymotors/ws/eB...m=130433030403
Old Sep 23, 2010 | 05:24 PM
Brutal's Avatar
We use gtr online and that looks like its pretty much a copy. Besides you cant go wrong for that price
Old Sep 24, 2010 | 07:12 AM
My fan still keeps running after the car is off...
Old Sep 24, 2010 | 07:29 AM
Brutal's Avatar
my fan still keeps running after the car is off...
it supposed to, just not on high speed. Tis a function of not only the cooling system operation but ac as well. The ecu will keep the fans running for what it sees in both systems
Old Sep 25, 2010 | 12:37 PM
baycliffpwds's Avatar
Originally Posted by Doug
Communication is everything. A customer can always ask "why" if uncertain.
OTOH.......
IMHO, if a customer leaves a repair shop with an estimate and doesn't know WHY a particular part and/or repair is being suggested then whoever wrote the estimate didn't do a very good job.
Baycliff left the shop with the impression that an unneccesary $850 repair was being suggested. Not good for business ! If we assume, for the sake of conversation, that Brutal is correct in his long distance assesment and a new headlamps IS needed, then the dealership shot themselves in the foot, big time. Not only did they not sell the job but the customer now feels suspicious about their recommendations. Lose-lose for the dealer.
In princemarko's case I wonder if anyone at the dealership showed or explained the depth and breadth of the labor involved. If they had then maybe, just maybe, marko might not be feeling like he got "raped". A $4400 bill is gonna hurt no matter how you slice it. But to pay $4400 AND think you got raped is twice as bad.
The headlight points where it's supposed to. If it didn't, I'd have asked the service manager about it when he mentioned it. My night vision isn't what it used to be; if I had felt there was a problem, I'd have that fixed pronto.
I wanted a Jag certified tech to go over it for their two cents worth. I had made it clear that David was going to check out the problems and make the repairs they said it needed, so the S.M. just rattled off a list. Their parts department might have made some money that day, but since he didn't explain the repairs needed, they lost sales. They lost my confidence years ago when I bought my Honda from their Honda division, but this is the only Jag dealership in the area.
Old Sep 25, 2010 | 12:46 PM
  #28
My fans never used to stay on after I switched the car off. And that radiator fan spins full blast.
Old Sep 25, 2010 | 01:48 PM
There is a fan that runs when I turn mine off, but it runs for less than five seconds and stops. There is a little fan behind the dash that's supposed to run, though. It makes a buzzing sound.
As for repairs to the tune of close to $5000., I might want a second opinion before authorizing repairs. Being a woman, before I was married I was ripped off for everything from paying for parts that were never replaced or didn't even need to be replaced, to being subjected to breakdown scare tactics. So, I'm a skeptic.
I hope you get everything repaired. Good wishes.
Old Sep 25, 2010 | 01:53 PM
  #30
Brutal's Avatar
then you have an issue, start the car and turn on the ac. Both fans must be running at low speed. be sure cause with 1 out the car will run hot. If thats ok, you have an issue with either ac pressure switch, system, coolant temp sensor and new t stat
Old Sep 25, 2010 | 01:58 PM
  #31
Brutal's Avatar
are you talking about the aspirator motor for auto climate control with interior temp sensor? Take the little grill off and will low pressure compressed air clean the aspirator(pc keyboard canned air works well)
On you head lights, maybe they properly checked them. I pull the high beam cover off and grab the high beam bulb connector and see if the assembly moves/flops around. Obviously it can still be broken and level. kinda like "I dont need an alignment cause my car drives straight" But theres steel sticking out on the inside edge from wear. Just have your X check it, it takes 30 seconds. And if theyre secure, then is 1 cluody, some people think you have to replace to fix cluody lights, but you really need them sanded down to get to virgin plastic then increase sand paper grit finer and finer then polish. We have a company that comes around to dealer (husband and wife team.) They do this and they look like new for years again, unlike kits that last a short period of time
Old Sep 25, 2010 | 02:50 PM
  #32
Thank you, Brutal. I'll get David to check that light out further. The plastic is a little foggy. At first I thought there was condensation inside the plastic cover but I read a post somewhere that described the sanding and polishing, and showed pictures of the job in stages. I'll get that done too. Maybe I'll do it with David's oversight to be safe.
I'd like to be able to do some easy things myself; I think it would be fun. I'm not afraid of getting my hands dirty; I'm just afraid of screwing up something. I already bought a throttle pedal sensor and replaced it when it didn't need to be replaced because I got the part name confused.
I can't remember the name of the little buzzing fan. A guy at work who used to own MGs told me about electrical problems in Jags after I bought the car and then I wondered for a bit if I'd have an electrical fire if the buzzing wasn't fixed. I asked about it when I bought some sensor that had to be replaced; a parts guy at the dealership said it will run for about 45 minutes after you open the driver door and it's normal. He said it keeps humidity out of the air conditioner. Well, ok, I live on the Atlantic Ocean and it's pretty darned humid, so I accepted that. I swear, all these little electronic gadgets are going to drive me crazy. I'm not sure what little grill you're talking about. I'll ask David to look at that too.
Some of the people at the dealership have been helpful. When I bought the car, I was told that the next 10,000 mile check up involved simple stuff and I could save myself the $300 dealership cost by having a mechanic go down a checklist that they gave me. The level of help varies depending on who you talk to there.
I appreciate your help!
Old Oct 1, 2010 | 05:39 PM
  #33
OK... so add another $800 for the fan assembly....
up to $5200.... lovin life...
Old Oct 1, 2010 | 08:02 PM
  #34
Markus's Avatar
Default Pauper prince....
or will be soon. Poor chap - I empathize with you. Sounds more like date rape than the forcible variety, though. Started out as an innocent and consensual relationship, that went horribly bad...
Old Oct 2, 2010 | 03:25 AM
  #35
Sean B's Avatar
man I'd pull it out of there. I can send you a fan assembly tested as good, year related for a 3rd of that. What's wrong with it? fans? wiring? If you need parts cheap, ebay uk. Eurojag ship all over the world, also Black country Jaguar. This assy. s/h in the UK is buttons.
e.g.
http://cgi.ebay.co.uk/Jaguar-XJ8-RAD...ht_2445wt_1137
Old Oct 6, 2010 | 11:02 PM
  #36
Here's the thing..
All the parts that were needed are wear and tear on normal cars after 100k... I realize that.
It just SUCKS to have to do this all in one swoop.
For $6000 that i've spent on this car to fix these issues, I should be driving a Mercedes CL65...
But at least I got to drive a 2011 Jaguar XF for 2 weeks now.... but I'll tell you guys this, the X308 Jaguar XJR are still far prettier cars. The XF's are a joke.
Old Oct 7, 2010 | 10:04 AM
  #37
technetx's Avatar
Wow that is a ton of money. I had all cooling hoses replaced, even the dreadful 2 that tightly fit under the supercharger, both valve cover gaskets, oil pan gasket and transmission pan gasket.... a whopping $1,200 TOTAL and it only took my mech a full day and a half. He had the intake and supercharger out in less than 2 hours. The great part is he only charges me for time and parts... couldn't care less what the book says. If you're thinking he does shoddy work, that work was done 80,000 miles ago and she still purrs like she was new.
Old Oct 7, 2010 | 10:44 AM
  #38
H20boy's Avatar
tech, sounds like a gem of a mechanic. If he's still in business, and you're willing to share , be sure to post up his information in the Regional section of the forum, members are always looking for competent and affordable independent shops. Word of mouth is still the best marketing out there.
Old Oct 13, 2010 | 12:45 PM
  #39
Add $400 for a new battery....
Old Oct 13, 2010 | 12:46 PM
  #40
Of course, I could have gotten all this work in Detroit for 1/3 of the cost... but being stuck here in Tampa, all these mechanics have gotten used to ripping off the elderly so the prices are inflated.
