Headliner Replacement - Los Angeles
Old Jul 26, 2011 | 10:32 AM
BonesXJR's Avatar
Default Headliner Replacement - Los Angeles
Anyone know of a good place for headliner replacement in the Los Angeles/San Fernando Valley area? I've got a few places in mind, but always prefer a referral. I'm concerned for my sunroof, as history has shown, they are prone to brake quite easily.
Thanks,
Jon
Old Jul 26, 2011 | 07:49 PM
supraman's Avatar
headliner replaced here in the bay area at a cost of 180 to drop the headliner and another 45 for the non-factory cloth. it was almost a perfect match, they had 55 to choose from.
my sunroof had issues before the headliner fix, a clip broke but i cant seem to find the clip, instead it seems i need to buy the entire assembly for 400 bucks. going to hold off for now as i just replaced the water pump and want her on the road again. good luck.
Old Jul 27, 2011 | 01:12 PM
bigdadbear's Avatar
Default Headliner replacement
Make sure they use original thickness 1/8 inch foam backed headliner. Any thing thicker and the sunroof will be an issue.
If you are a DIY see WIS Headliners on the net, they carry 1/8 inch headliner. ---3 yds of material at $45.00 and 2 cans of 3M 08088 adhesive from walmart for $20.00--- for $65.00 your done.
The 3M adhesive is good up to 180 degrees and will not bleed through lighter colored headliner. You must apply it to the Headboard and the Headliner.
Old Feb 16, 2012 | 11:13 PM
cstu's Avatar
Has anyone in the LA area had this done? I'm considering E&C Jr Auto Upholstery but it would be great to have advice from someone who has had their Jag repaired.
Old Feb 20, 2012 | 03:31 PM
JagMarc's Avatar
Try Rauls Auto Trim on Holt in Ontario, he did my 73 XJ6 perfect!
Forcedair1
Sep 8, 2025 01:57 PM
Wolfy
May 28, 2024 08:06 AM
RoyLittle0
May 25, 2023 02:38 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
