Which heater hoses?
Old Apr 1, 2013 | 07:40 PM
coastaljag98's Avatar
Default Which heater hoses?
When I pull my intake and replace gaskets which hoses and what part numbers? I want to be gathering everything up so I have it ready.
Old Apr 2, 2013 | 08:53 AM
OldMike's Avatar
Well, I called Welsh Enterprises and spoke with Amy (extension 166, if you're interested, but I'm sure any of their reps can help) an she hooked me up with the following parts.
Heater hose feed, Part # NCA-3945-CD, $13.95
Heater hose return, Part # NNE-3946-CA, $21.95
Intake Manifold Gasket, Part # NCA-3016-BB, $3.95 each, need 8
Injector O-ring Kit, Part # JLM-20291, $16.95 each, need 8
Part Load Breather Tube, Part #AJ8004880, $27.00 (approx.)
You might need other parts, but these are the one I have on order. Hope this helps.
Mike
Old Apr 2, 2013 | 09:55 AM
JimmyL's Avatar
FWIW, I used regular old heater hose from an auto parts store for the heater feed and return lines that go under the intake manifold. They didn't look like they were anything out of the ordinary. I can't remember the size though, 5/8" or something close. I tried to make sure they rested on the "mat" under the intake. That thing appears to be there so that they don't lie on bare metal.
Old Apr 2, 2013 | 07:21 PM
Thanks guys that's what I needed. Wouldn't have even thought about injector o-rings. .
Old Apr 3, 2013 | 08:33 AM
JimmyL's Avatar
Actually, you don't have to remove the injectors when removing the intake manifold. Just FYI.
mikiep
Dec 20, 2019 07:37 PM
xjrjag
Oct 12, 2015 03:16 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
