help: 2000 xjr leaking coolant
Old Sep 10, 2011 | 02:03 PM
JagYi's Avatar
Default help: 2000 xjr leaking coolant
Help!
I borrowed a pressure tester from autozone and confirmed there is indeed a coolant leak on my 2000 XJR.
It seems it's coming from the engine housing somewhere. I can't find the source of the leak. Please help. I've included pictures below.
Can someone identify the source of this leak? Is there a water hose under there or the water pump sealant is leaking?
http://gslgsl.shutterfly.com/pictures/16#16
http://gslgsl.shutterfly.com/pictures/16#15
Old Sep 10, 2011 | 02:24 PM
JagYi's Avatar
Ok, added a youtube video for the 2000 XJR coolant leak for better diagnostics.
My vehicle mechanical rating is up to 3/10 after getting this jaguar and still learning.
2000 xjr coolant leak detected using pressure tester - YouTube
Old Sep 17, 2011 | 04:52 PM
johnleavitt's Avatar
Just a guess, but it could be the hoses under the blower, as I found out. Major pain, but I used the opportunity to change all the hoses and water pump. I felt really good about it, and then my kid ran into a curb a couple of days later, cleaning the right front wishbone off the frame. I think the car is going to be totaled. Too bad. A lot of work went into it.
KarimPA
Sep 12, 2015 08:15 AM
OkieTim
Sep 8, 2015 04:48 PM
Xkr x100
Sep 6, 2015 08:50 AM
OkieTim
Sep 2, 2015 12:48 PM
