Help with list of items I need for MOT..
Hi all.
Assuming the problems have not worsened since the MOT last year, what do I need to buy for my MOT which is due in two months?
Repair as soon as possible (minor defects):
- Offside Front Lower Suspension arm ball joint dust cover severely deteriorated (5.3.4 (b) (i))
Monitor and repair if necessary (advisories):
- Nearside Front Lower Suspension arm ball joint has slight play (5.3.4 (a) (i))
- Rear Sub-frame corroded but not seriously weakened (5.3.3 (b) (i))
- Rear Fuel Pipe/s corroded ()
- Rear Lower Underside body corrosion .
- Nearside Front Lower Shock absorbers has a slightly worn bush (5.3.2 (c))
- Offside Front Lower Shock absorbers has a slightly worn bush (5.3.2 (c))
Kopi
02-19-2016 08:41 AM
