Help!! X308 leaking fuel excessively
Old Jul 28, 2023 | 09:35 PM
ericnunez's Avatar
Default Help!! X308 leaking fuel excessively
Hey all as the title says, my XJ8 is absolutely leaking fuel, it appears to be coming from a fuel line, what the hell do I do??! I can't even reach the line to cover it with something. I have $80 worth of fuel in there and the mechanic will not be open until tomorrow. I cannot keep the car leaking on the street!!
Heres a link to a video that shows how bad the leak is.
http://youtube.com/shorts/-mYVHyJ7CMA?feature=share
Old Jul 29, 2023 | 06:38 AM
Addicted2boost's Avatar
You’ll have to jack up the rear of the car and use jack stands. Crawl under the car with a flashlight and find out where it’s leaking from. If I had to guess, I’m going to say somebody foolishly pulled the tank out without disconnecting the lines from the bottom of the tank first so the lines got damaged.
Old Jul 29, 2023 | 08:30 AM
Quadcammer's Avatar
Check the fuel filter connections
Old Jul 29, 2023 | 09:41 AM
ericnunez's Avatar
As far as I'm concerned, nobody has touched the fuel tank or fuel line. I just picked it up from the mechanic's yesterday though and and noticed it was smelling like gas super bad. Pulled over and saw the huge amount of fuel spilling onto the exhaust pipes. Could it possible be due to a bad bushing set? The side with the fuel leakage is also the side with a really bad metal clanking sound. The leaking slowed down a bit now, its at about 1 drop every 5 seconds.
Old Jul 29, 2023 | 10:08 AM
M. Stojanovic's Avatar
If I'm not mistaken, it is dripping at the side where the fuel filler neck is. Perhaps a leak is from the fuel filler pipe itself, leaking only when the tank is filled to the brink?
Old Jul 29, 2023 | 10:43 AM
ericnunez's Avatar
That's what I thought too, but I only filled half the tank, unless thats somehow too much fuel too..
Old Jul 29, 2023 | 10:52 AM
What work was done to your car yesterday (or earlier this week)?
I would be very surprised if that was the original fuel pump after 23 years. If it is the original fuel pump, you may want to have it replaced sooner than later.
Old Jul 29, 2023 | 01:07 PM
Jhartz's Avatar
Start by opening the gas cap to reduce pressure . . .
Old Jul 29, 2023 | 01:48 PM
ericnunez's Avatar
yes it is, hasnt been replaced by me or the previous two owners(according to their records). the only two things that were worked on the car this week was replaced an oxygen sensor and my mechanic inspected the rear left suspension because it was making a knocking noise. But he didn't actually swap anything out. I don't see why the mechanic would go anywhere near the fuel lines.
Robtrt8
Dec 13, 2022 05:05 AM
harmon1640
Sep 16, 2022 12:28 PM
Prange
US Midwest
Jun 23, 2018 09:25 AM
thuffner3
Aug 4, 2012 01:12 AM
Grant Francis
Feb 13, 2012 01:15 PM
