Help With XJR!
Old Sep 17, 2019 | 02:36 PM
Vegas_Jag's Avatar
Default Help With XJR!
I need help, passenger door isn't locking when I lock my car nor is the window switch working, I have a 2000 XJR.
Old Sep 17, 2019 | 04:33 PM
NBCat's Avatar
Check the wiring loom from the door to the body for damaged wires or connections.
Old Sep 17, 2019 | 05:09 PM
Welcome to the forums Vegas_Jag,
I've moved your question from General Tech Help to X308 forum. This is the place to post technical questions about your model.
Old Sep 18, 2019 | 06:34 AM
dwgates's Avatar
The wiring may be where the issue lies but you may just have to do a "hard reset".
When my 99 showed up there were a few things that didn't work (several of the windows if memory serves) and I thought it was something I'd done since the first thing I tackled was a broken door release cable.
I thought I'd made a mistake when reconnecting the switches when I put the door panel back in place.
Nope, the hard reset (you can look it up but it's just disconnecting the positive terminal form the battery and holding that to the negative post of the battery) was what fixed it.
I'm not sure but the explanation for why this works is it bleeds any charge that might be sitting on a capacitor in the system.
You may still need to dive in and look at wires but I'd try this first.
There's plenty of posts here regarding what this helped with.
Good luck..
Old Sep 26, 2019 | 01:52 PM
Vegas_Jag's Avatar
Thanx I'll try that this weekend, it just stopped working out of the blue, just sucks because my passenger door doesn't lock!
Can make it so I can lock/unlock manually?
sinatrakat
Apr 23, 2021 10:45 AM
electrovolt
Aug 1, 2014 05:22 PM
Ipc838
Oct 4, 2012 04:06 AM
james henry
General Tech Help
Jul 22, 2012 10:17 AM
