How to fix the leak of this part?
Old Jun 15, 2018 | 03:14 PM
banar's Avatar
Default How to fix the leak of this part?
I own 2003 XJ8 and have a leak in my system so the valve cover gasket has to be replaced. However, I see that it's leaking a lot from one specific place as I showed in the photo. Could you please advise what part I have to purchase to fix this?
Thank you in advance.
Old Jun 15, 2018 | 04:42 PM
avern1's Avatar
That is the VVT solenoid. It has an oil seal that can be replaced without removing the Cam Cover. You need to pull out the old seal. I have used a screw drilled into the seal housing and levered it out.
I would recommend before you change the seal, you should check the Part Load Breather Pipe for obstruction. When you remove the part load breather in the fitting is a small orifice that you need to make sure is clear and open. You can use a small drill bit to open it up.
If the breather or orifice is plugged it creates pressure in the crankcase and causes Cam Cover leaks.
Old Jun 15, 2018 | 07:58 PM
Carnival Kid's Avatar
The VVT oil seals are part # AJ8-2856 and can be purchased from many sources, just do an internet search.
Old Jun 15, 2018 | 08:43 PM
banar's Avatar
Great, thank you. I will be replacing it together with valve cover gaskets.
steveinfrance
May 31, 2024 10:57 PM
DayOff
XJ40 ( XJ81 )
Aug 12, 2016 10:03 AM
Sean W
Aug 20, 2014 12:16 AM
jameson
Sep 9, 2012 05:57 PM
cutlass
Feb 22, 2010 03:21 AM
