How to Tell if Hub is Bad
Old Jan 17, 2012 | 05:28 PM
01vandenplas's Avatar
Default How to Tell if Hub is Bad
Hi,
How can you tell if Hub is bad?
Attached pix of drivers side left rear hub from 01 Vanden Plas.
Any assistance appreciated.
D
2001 Jaguar Vanden Plas X308 - 165k
Attached Thumbnails How to Tell if Hub is Bad-hub1.jpg   How to Tell if Hub is Bad-hub2.jpg
Old Jan 17, 2012 | 06:26 PM
Brutal's Avatar
They go bad from leaving a bad bearing go too long. Look at the area that the bearing rides. If any wear from the inner race spinning on the hub its bad. The other isse is a warped hub. You have to really check this on the car with a dial indicator set to run on the cleaned flange just past the studs so they wont hit the dial indicator. Is has to be perfect.000. I dont care what anyone says about hub "tolerances" if you have say .001-.002 on the hub, that equates to about .008-.012 on the rotors outer edge and this is unacceptable
MrWhite
19
Jun 14, 2022 07:49 PM
Joachim1167
Nov 7, 2020 09:18 PM
Dave1109971
Dec 15, 2015 06:16 PM
MrWhite
Oct 1, 2015 01:43 AM
Dave1109971
Sep 30, 2015 11:04 PM
