Idler, pulley diagram help
Old Aug 16, 2023 | 08:08 PM
98Jagxjr's Avatar
Default Idler, pulley diagram help
I need to order a new pulley it doesn’t spin smoothly what the name of this pulley I’m a little confused.
Old Aug 16, 2023 | 09:12 PM
X7.62x51's Avatar
it's the supercharger belt idler pulley.
please confirm on yours with the pictures on the following site:
https://www.autoreservejaguar.com/xj...er-pulley.html
Old Aug 17, 2023 | 03:23 AM
Peter_of_Australia's Avatar
@ 98Jagxjr: You did not write, in which country you are...
The link above gives you a price of 32 Pounds....
I strongly recommend two things:
1. Remove the pulley, of which the bearing if probably buggered. If it is a metal idler pulley, you will most likely be able to swap the bearing (assuming you have an hydraulic press). If not, take your idler pulley and go into any automotive accessory shop - They will most likely have a generic pulley (which is the same) for about 1/4 if the price above.
2. When you have removed the drive belt anyway (to remove the idler), check, if all the other pullers are well & sound. The is a chance, that you will find another idler puller with the same issue...
jafo1970
Apr 14, 2023 09:23 PM
Akwarr
May 1, 2018 09:32 AM
User 070620
Mar 16, 2016 09:27 AM
trucknetjack
May 1, 2015 03:40 AM
