Ignition getting sticky
Old Jan 21, 2016 | 01:12 AM
Pilotman11's Avatar
Default Ignition getting sticky
Good day everyone!
Recently my ignition sometimes sticks and I have to remove the key and re insert it and so on until it turns.
I'm guessing it needs a lubricant; what would you use? I'm thinking WD40 only because it does not conduct electricity, and does not gum up if the key if it's wet,ect. However since it's a solvent as well I'm worried about applying some.
I had the same problem on my door lock and after using WD40 it works flawlessly.
Thanks!
- Pilotman
Old Jan 21, 2016 | 02:25 AM
King Charles's Avatar
Get powdered graphite available @ any hardware,box stores etc. WD-40 attracts dust & dirt that will gum up over time I've found.
Old Jan 21, 2016 | 08:57 AM
Jhartz's Avatar
graphite is best (you have heard this before) once the lock is working smoothly -- first, clean the lock (hint: WD 40 or an equivalent -- I like CRC's or MPS, less residue than WD 40, a concern that KC notes, above). Just my opinion.
OBTW - have you lubricated the trunk (boot) lock, yet? You might like to also lube the door hinges while you have the can out.
gthawk1
Jan 6, 2016 11:03 AM
NtAFord
Jan 4, 2016 04:44 AM
etaent
Jan 4, 2016 02:10 AM
dhog4n
Dec 31, 2015 09:31 PM
