Instrument change, plug and play or programme it?
Old Sep 5, 2017 | 04:33 AM
v8pete's Avatar
Default Instrument change, plug and play or programme it?
Hi guys, it appears i have can failure on my instrument pack, im hoping for a quick fix and was wondering if another instrument pack from the same year of car will plug in and work without having to reprogramme it to work? I have done the backplate solder issue but still have warning lights no speedo rev counter or display, i have tried to look into this but am getting conflicting answers, Jaguar say it will need programming, other people are saying it will plug and work. I just want my Jaguar working as it should, anyone on here know the answer?
Thanks guys
Old Sep 5, 2017 | 06:33 AM
Sean B's Avatar
What year car? SC, 4.0 or 3.2?
It depends on which IPK you replace it with, if you have an exact parts number match - by looking in the trunk spare wheel well shoulder panel, there's the CATS LIST and will list the IPK part number along with it's actual programming code - you need these numbers to match for plug and play.
If you require further details, do a search, a thread by Jim Lombardi has this subject discussed at length...hope that helps.
