just bought my first jaguar xj8! how do I lower it?
Old Apr 18, 2015 | 01:13 AM
johnnyLFC's Avatar
Default just bought my first jaguar xj8! how do I lower it?
Im new to this site and new to Jaguar! I just bought an 04 xj8 and love it! But I want to lower it...im planning on doing it myself or of theres anyone in the so cal area that can do it.. Any instructions will be greatly appreciated...
Old Apr 18, 2015 | 03:01 AM
Daim's Avatar
Hi and good choice!
I plan on doing the same with my XJ8 once it is totally up to my standards...
Lowering springs are hard to come upon. Either Mina (Mina Gallery) or custom ones (there is a company in GB who makes custom springs for the XJ8 - search eBay.co.uk).
Removal is fiddly. The rear axle isn't the worst part if you remove the struts properly and find that the bolts/nuts aren't rotted. If they are rusty, then it won't be that fun!
The front axle is selfexplaining. No McPherson struts or coil overs... Just standard damper and spring combination.
Make sure you adjust the rear camber (there are little camber plates mounted between the driveshaft and differential flanges!) and check the fronts. An alignment is of course mandatory.
As said, if you look at the suspension setup, it is selfexplaining. And NO, X300 springs will not fit up front. In the rear they will. The fronts should be the same as those from an XK8...
Old Apr 18, 2015 | 10:14 AM
johnnyLFC's Avatar
Thanks for the advice!! But I just jacked up my car and it has air shocks. Is there any way to lower the height sensors??
Old Apr 18, 2015 | 11:14 AM
Daim's Avatar
Just seen... You've got an X350 (not X308). The model where the inner headlights are smaller than the outers... You'd be better to ask in a different area here, as the 308 and 350 are two totally different cars...
Old Apr 19, 2015 | 06:31 AM
parwun's Avatar
Recently installed powerhouse.co.uk uprated lowering springs on my XJR, it got down about 25-30mm. However Iam very happy with the result, even if its not low as You might expect, the comfort ans smoothness have also increased! so overally I got lower stiffer and smoother suspensin now.
They can also make lower springs, but they did not reccomend it in terms of comfort.
Old Apr 19, 2015 | 08:40 AM
Daim's Avatar
Now that sounds good!
Have you got a link or is that the Ebay UK seller?
Old Apr 19, 2015 | 02:35 PM
parwun's Avatar
1997 - 2003 Jaguar XJ XJ8 XJR XJ-R Performance Lowered Uprated Road Springs | eBay
thats the place
philwarner
Dec 6, 2021 07:13 AM
GroovyMom
Sep 3, 2015 08:08 PM
peterg19
Aug 28, 2015 08:42 AM
Terencex
Aug 26, 2015 08:47 AM
souldoubt
Aug 25, 2015 08:15 PM
