key cant get into the keyhole all the way
Old Oct 11, 2012 | 05:04 PM
vincent661983's Avatar
Default key cant get into the keyhole all the way
Hi,this has been an on going issue almost ever since I have purchased the car but I think it is time to pay attention on it
initially, key worked fine at the door since I did not even have my fob yet. Once I programed a fob (perhaps not even related) , I realized I cant put the key all way in the keyhole anymore but it only takes like halfway
I want to know what went wrong and how to fix it.
note:WD40 did not work
Old Oct 11, 2012 | 05:56 PM
WD40 is not suitable for locks. It was developed as a water dispersant (hence the name) and is not a lubricant. Over time it dries out which is probably why your lock has become inoperable.
Locksmiths use liquid Graphite, powder Graphite or Houdini Lock Lube as a lubricant for locks. For a partially seized lock, the liquid Graphite or Houdini spray will likely be the most effective in freeing the lock and then keeping it lubricated.
Old Oct 11, 2012 | 06:03 PM
thanks,like I said before, learning something new everyday by owning a Jag
Old Oct 12, 2012 | 03:46 AM
steveinfrance's Avatar
Try putting the lock lubricant (if you can get some) or a light oil like 3 in 1 on the tip of the key and then gently wiggling the key as you push it home.
Just pray that some joker hasn't pushed a matchstick into your lock.
philwarner
28
Jul 11, 2017 10:21 AM
jospolice
Oct 2, 2015 07:16 PM
Listers
Sep 30, 2015 07:45 AM
Jzar
Sep 27, 2015 02:55 PM
