Leaky jaguar
Old Dec 20, 2017 | 05:16 PM
Jaguarstyper's Avatar
Default Leaky jaguar
I have a Jaguar that leaks from the panel under the battery, and no its not a flood car, and no jaguar wasn't a help. So do any of you have a suggestion
The water the last few days was clear this was dirty from 14 years of me not owning the car
Old Dec 20, 2017 | 05:21 PM
NBCat's Avatar
Typically water leaking into the boot is from above, not underneath.
Check moon roof drains and rear window/backlight sealing.
Old Dec 20, 2017 | 05:28 PM
Lady Penelope's Avatar
There are 2 drain lines ( L & R ) that come down from the roof line and the tube goes through a hole in the sheet metal to exit . The line may be pulled up and out of those sheet metal holes . Located close to the wheel arches . Otherwise the hoses get clogged
Old Dec 20, 2017 | 07:40 PM
There is one wire that is disconnected unfortunately I had a faulty battery so no lights on the car I will get a picture up tomorrow if you wouldn't mind checking
Old Dec 20, 2017 | 10:33 PM
Make sure you install the battery with the positive post in the positive direction of travel . A service garage will even error as it's a bad thing if not correct .
SteveM
Motorsports
103
Oct 19, 2024 02:58 PM
