vincent661983
close
- Join DateOct 2010
- LocationNew York
Liked:169 Times in 142 Posts
I know it's not a new topic at all. any one using the LED for the rear lights can advise?
My understanding is adding the resistor could resocer the kssis but given the physical deisgn of the rear light panel (in kne piece).
I am running out of my brain cells
LED lights on the rear need to be designed for CAN bus systems, they basically have a Load resistor in parallel with the lamp to fool the system that the correct current draw is being used, which is used for the sensing that the bulb is working
vincent661983
close
- Join DateOct 2010
- LocationNew York
Quote:
Roy, so what is the resolution are you suggesting?Originally Posted by RoyLittle0
