A little assistance please
Old Oct 23, 2014 | 11:37 PM
dsnyder586's Avatar
Default XJR vacuum hose routing- RESOLVED
I just redid the coolant lines in my daughter's XJR It was back breaking. I love a challenge, but I will tell you it would almost be easier pulling the engine and doing it.
I neglected to label the vacuum lines which broke upon removal (idiot) and am not sure if I replaced them correctly- does anyone have a diagram of how they go?
I now have them like this:
Vacuum line from top of supercharger teed off to fuel supply vacuum, then teed off again to the S/C bypass, then teed off again to the intake elbow and the valve on the bulkhead (vapor?)
I worked late and was tired, so that was a bad idea- I even crossed the coolant lines to the reservoir!
Old Oct 24, 2014 | 06:14 AM
xjay8's Avatar
BUMP! ;o]P
Old Oct 24, 2014 | 01:08 PM
dsnyder586's Avatar
Thanks!
Old Oct 24, 2014 | 04:45 PM
dsnyder586's Avatar
OK- I THINK I have it figured out, so here you go for those who may need it in the future:
Fuel Pressure Regulation and Cruise Control Vacuum Feed-
The inlet vacuum feed for the fuel rail pressure regulator and the cruise control system is taken from the
supercharger outlet duct. The feed pipe is located below the large charge air cooler coolant filler plug. (ONE DIRECT CONNECTION, NO tee)
The intake elbow vacuum goes to a tee, which feeds the S/C bypass valve and the Emissions thingie on the bulkhead.
Old Oct 24, 2014 | 05:28 PM
Jhartz's Avatar
I am worried about you: need help on vac lines and plastic radiator hoses, but think REPLACING AN A DRUM is EASY!!! Sounds like me after Single Barrel Jack Daniels.
Old Oct 27, 2014 | 10:32 AM
dsnyder586's Avatar
lol- sometimes it's the easiest of things that get me stumped. I should never work on a car with an empty stomach when tired.
RickyJay52
Sep 20, 2021 04:48 AM
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
10 XF Premium
Sep 20, 2015 12:51 PM
