Minimum oil pressure at idle??
Old Sep 18, 2011 | 05:07 PM
smitty5534's Avatar
Default Minimum oil pressure at idle??
Does anyone know what the oil pressure range should be at idle and what it should be at like 3000 rpms? 98 xj8 cant find any info on it thanks in advance
Old Sep 20, 2011 | 01:05 PM
Fyrplg's Avatar
Nobody wants to touch this one...
My oil light came on in high 90's weather at idle (8PSI). just slight increase light went out.
Talked with mechanic, probable not screen on pickup (that would be more likely at high RPM under accelaration).
Oil pump (10 hrs labor plus Jag 400 plus $$ for pump).
What I did (my decision for me only) was use a heavier oil grade.
No oil light problem since.
99xk8guy
May 28, 2024 09:36 PM
tomsjag
Jun 10, 2023 10:02 AM
Bcrary3
Feb 21, 2023 04:29 AM
Scarecrow
Mar 28, 2016 03:17 AM
giandanielxk8
Sep 6, 2015 07:21 PM
