Misfire x8!
Old Aug 9, 2022 | 02:51 PM
swimman's Avatar
Default Misfire x8!
I have a 2001 Vanden Plas that threw a check engine light with misfire codes - P0300, 0301, 0302, 0303, 0304, 0305, 0306, 0307, 0308, P1316, P1111. All related to misfire. Could be related to a host of things but where should I start? Coils?
Old Aug 9, 2022 | 03:59 PM
Quadcammer's Avatar
would be unlikely to have 8 bad coils. More likely you a wonky sensor like the MAF, cam sensor, VVT, or similar that may be causing the issue. Could also be a wiring connection to the ECM, a bad ground, etc. You will likely need to spend some time determining when the misfires occur. Not sure, but even something like a bad or blocked EGR can cause misfires.
Old Aug 9, 2022 | 05:05 PM
NBCat's Avatar
A failing or weak battery can cause random DTCs. Start any diagnosis with a fully charged battery that has at least 12.6 volts available across the terminals with the ignition off when checked with a voltmeter.
Old Aug 10, 2022 | 12:00 PM
Jhartz's Avatar
When it is all cylinders misfiring - P0301 - 0308 - it is almost always a bad secondary tensioner causing faulty timing. Have they been changed?
Once, over on the XK8 forum, everyone jumped on timing -- moi, aussi -- it was a bad lead to the coils. Only time on this forum, that I remember, where it was NOT timing!!
Jeffrey David Benson
Feb 9, 2022 11:31 AM
Winster69
Jul 9, 2017 08:34 AM
earthdogjim
Mar 24, 2017 04:18 PM
slmskrs
Oct 27, 2015 11:47 PM
darrenshadbolt
Jul 7, 2010 11:03 PM
