Misfires on all 8 cylinders
Old Sep 23, 2013 | 02:30 PM
sheddist's Avatar
Newbie here!
Have just replaced the thermostat tower and the heater and breather pipes lurking under the manifold. Obviously, manifold was removed. Re-assembled with new manifold gaskets. Difficult to start first time, started OK. No power, no revs but idle just a little lumpy. Codes 1316 and 0301-0308 displayed. Checked plugs on one bank and all clean and the right colour. Old Mike, what was the cause of the problem with yours?
Old Sep 23, 2013 | 03:12 PM
OldMike's Avatar
I believe the cause was re-using the manifold gaskets but I had the guy take it all apart and reseat everything, plus he soaked the gaskets in petroleum jelly -- after putting it back again, it worked fine.
Old Sep 23, 2013 | 04:01 PM
sheddist's Avatar
Mike,
Thanks for a quick reply, seems that it is air leak related then... More spannering needed then.
Old Sep 23, 2013 | 05:12 PM
OldMike's Avatar
Yes, it was an air leak -- you could hear it with the hood/bonnet open and the engine running. At one point, I got the error message to go away by doing a hard reset, but it came back after driving just a few miles.
I forgot to mention that he also took the fuel rails out and said he needed new gaskets for those, too. Jaguar doesn't sell the gaskets, so he quoted me a price of about $200 per injector and said I needed all eight of them! I told him he was nuts and insisted that he re-use the old gaskets. I did find a set on ebay for about $35. I think I still have them around here somewhere and figured I'd use them if the problem comes back.
Old Sep 23, 2013 | 08:20 PM
sparkenzap's Avatar
For the archives, this is a good reason NOT to follow the repair manual's direction to remove the intake manifold ro replace the thermostat tower. Just break it off with pliers (you are installing a new metal one anyway) and then you can get to the bolts. Replace the bolts with socket head capscrews and be done with it!
Old Sep 23, 2013 | 09:22 PM
WaterDragon's Avatar
I would have been surprised if he did not break the part load breather hose...old ones are usually very brittle.
Unfortunately these gaskets are not reusable. They are rather low quality in my opinion too. Any time you remove a manifold in the future, always use new gaskets, costly, but the cheapest way to go. I too learned this the hard way.
Old Sep 24, 2013 | 04:25 AM
sheddist's Avatar
Well, idle is OK, as is moving from park to drive, but blipping the throttle causes all sorts of hesitation and spluttering. Attempting to drive results in a 10 mph crawl.
Part load breather has been replaced and disconnecting it does cause a change in idle so I think that is OK. The fuel rail and injectors were not removed from the manifold.
I am thinking that it could be the inlet pipe from the throttle body to the MAF as the sympptoms suggest that the "system" is not able to respond to opening the throttle. Removing it could have split it so air is bypassing the MAF. Much prefer MAP based fuelling as there are fewer joints to go wrong!
Old Sep 24, 2013 | 08:32 AM
  #28
JimmyL's Avatar
Replacing the part load breather hose is a good thing to do while the intake manifold is off. I can't imagine trying to replace it with the intake mainifold on. I have had experience with one leaking also, and it will mess with your mixture.
Old Sep 24, 2013 | 12:37 PM
sheddist's Avatar
Seems to be sorted.
Looks like it was an air leak at number 8 manifold to head where it had not properly seated. Dripped water onto each joint to hear number 8 give a sizzling noise as the water was drawn in.
Gave the MAF a clean too.
Car now is drivable. Good test run needed to recalibrate the ECU.
Thanks for your help, much better response than a certain other forum.
Old Oct 1, 2013 | 02:39 PM
  #30
sheddist's Avatar
To put this one to bed,
The remaining misfire (not fault codes flagged) was due to a faulty new inlet manifold gasket.
All now replaced with blue ones made from what looks like silicone rubber. Thicker and softer then the previous green ones.
[URL=http://s83.photobucket.com/user/sheddist/media/badgasket.jpg.html]
Car drives properly once more.
Old Oct 1, 2013 | 04:15 PM
  #31
OldMike's Avatar
Glad you got that sorted out. I'm tempted to check my manifold gaskets, but since my car runs almost perfectly (but not quite!), I think I'll leave it alone for now!
aode06
Jul 28, 2023 02:26 PM
pnwrs2000
Nov 17, 2015 04:04 AM
Delta66
Oct 4, 2015 05:40 PM
reb1999
Sep 26, 2015 08:41 AM
