missfiring on a 2000 xj8
Old May 19, 2011 | 05:06 PM
Forceofhabit's Avatar
Unhappy missfiring on a 2000 xj8
Please help....I started my car again after driving about 20 miles and it started missfiring...Cyc's 5,6,and 8 are sending codes that they are missfiring....What could my problem be?......I tried resetting the computer....Think its coils
or wires?.....Please help, its my only car......
Old May 19, 2011 | 11:22 PM
sparkenzap's Avatar
Yikes. That's three of four on one side. Check your left side secondary tensioner and chain. You might not have bent the valves YET! Take heed. Don't crank it until you have checked the tensoner.
Old May 20, 2011 | 08:02 AM
is that all under that shroud covering?....I have to check to see where that is...And yes, thats the side I hear it being noisy....404-295-2325
Old May 20, 2011 | 08:16 AM
Talking missfires on 2000 xj8
Thank You Ross!
Old May 20, 2011 | 10:18 AM
sparkenzap's Avatar
I gave you a shout and left my number-
You will need to remove the left side valve cover- It is not too bad on a normally aspirated XJ8. Look in the XJ8- XJR forum section and "sticky notes" to get an idea of what I refer to. If the engine ran, although poorly, there is a good chance you have not bent the valves. If the valves are bent, it requires removing the cylinder head to repair, which is a way bigger deal than just fixint the chain tensioner!!!!!
bdboyle
Sep 16, 2019 05:58 PM
donald ebanks
Sep 30, 2015 07:08 PM
Camnelson324
Sep 27, 2015 08:48 AM
pino
Sep 26, 2015 08:05 PM
mikin
Sep 26, 2015 10:21 AM
