Name this connector!
Old 04-27-2017, 01:14 PM
vsol's Avatar
Default Name this connector!
this electrical connector is at the rear of the engine on the underside of the car near the trans. I need to replace mine and I don't know what it's called
Old 04-27-2017, 01:27 PM
nilanium's Avatar
If the transmission is at the top of that picture, I believe that is the crankshaft position sensor, the thing you take out for putting in a locking pin in for timing stuff
If you need the connector itself it should be listed in the electrical guide
Old 04-27-2017, 01:36 PM
vsol's Avatar
the picture is the back of the engine block where it exploded
Old 04-27-2017, 01:41 PM
Daim's Avatar
Received 2,180 Likes on 1,583 Posts
Crankshaft sensor. It is attached to the rear of the engine and works on the flywheel/flexplate.
