New alternator connection double check.
Want to make sure that it is New red to Yellow and New black to White and blue
the new connector should only be able to be inserted into the alternator only 1 way and not be able to spin it 180 degrees
try it and then you will know the wire color match up
the center wire White / Blue strip will not change position.
