New to Jaguar
Old Feb 26, 2011 | 09:02 AM
Big Daddy's Avatar
Cool New to Jaguar
Hey guys,
I have recently traded my BMW 525i for a 2000 Jaguar XJ8.I did most of my own work for the BMW. The first thing I got was a Bently repair manual. It was extremly helpfull. I have done some searching and have found a Jaguar repair manual on ebay for 24.95. Is this manual a good resource. if not can someone recommend a good repair manual. If anyone has a BMW 2002 525i I have a manual for them if needed. Also, I need to replace my themostat. It has been recommended to me to replace the plastic housing with the Aluminum version. Do you guys know if I all so need the housing cover and housing cap. Or does the aluminum kit come with this. If any one can advise, I would be in your debt. Thanks.
Old Feb 26, 2011 | 09:17 AM
Gus's Avatar
Gus
Hello and welcome to jaguarforums.com. I know that you are anxious to get started and we are anxious to meet you and talk about your car. We have a baseline / criteria that must be met before full access can be granted. Please enjoy the forum and be patient once the baseline has been satisfied full access will be granted. Please continue to post and accept my welcome to the forum.
Please take a moment and read the information provided to you explaining the rules. https://www.jaguarforums.com/forum/new-member-area-intro-must-5/ Be patient and enjoy the site.
As for your question I would suggest contacting the supplier and see what they say.
Old Feb 26, 2011 | 06:20 PM
test point's Avatar
While there may be printed manuals, the official Jaguar service and repair manual, including the electrical schematics is the Jaguar Technical Information System (JTIS). It is available as a free download here:
https://www.jaguarforums.com/forum/s...ead.php?t=9933
It can also be found on eBay as a CD all the time for $10 or less. Don't fall for all the hype about a 'complete' version for $29.95 or higher.
Many complain that it is difficult to use but I discovered long ago that reading the instructions unlocks a magical lock that makes everything available. ALLDATA also has a subscription service based on JTIS but with more intuitive access for about $30 per year.
My aluminum housing came with the thermostat, the 'O' ring and the screw on cap but as GUS says, check with your vendor. Consider painting it black as the bright aluminum looks a little out of place in the center of an otherwise black engine.
You will have to put up with the 3 day, 10 post restrictions of the forum. It makes you and I safer from trolls, hackers and spam.
. . . and welcome to the wonderful world of Jaguars!
Old Feb 26, 2011 | 10:12 PM
Rae's Avatar
Rae
Big Daddy: Welsh Enterprises has an aluminum thermostat kit. Also, do a thread search for replacing thermostat. The rear nut/bolt can be tricky but possible with some ingenuity. Good luck & Welcome to the forum.
Old Feb 28, 2011 | 04:30 PM
Big Daddy's Avatar
Cool New to Jaguar
Thanks Test point i appreciate the advice. Would like to try and download the Jaguar manuals. Thaks for the help
Old Mar 4, 2011 | 10:34 PM
tjb909's Avatar
Default Welcome Big Daddy!
Good to see some newbies..
Make sure you go through the checklist for that year Jaguar, it can be found on this board..
Best Of Luck!
JarodL
Mar 7, 2024 01:39 AM
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
David Thompson
Sep 3, 2015 07:48 PM
bkeats
E type ( XK-E )
Sep 2, 2015 09:38 AM
