No dash lights
Old Nov 9, 2009 | 09:14 AM
xj8xj8's Avatar
Default No dash lights
My dash lights are goofy. They work when the lights are off and with the parking lights but as soon as you turn on the headlights the all dash lights turn off making it impossible to see how fast or even seeing the radio when driving at night. I searched this and found somewhat similar problems with the turn signal lever being the problem. Anyone have any other recommendations?
Old Nov 21, 2009 | 12:37 AM
xj8xj8's Avatar
For the record.
A broken wire on the turn signal switch will cause this. Replacement of the turn signal is the fix. Also make sure to replace the 5amp fuse on the LH fuse box under the rear seat as this will supply power to the dimmer module again.
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
jagent
Sep 12, 2015 01:40 AM
mrplow58
Sep 9, 2015 11:27 AM
02jagstype
Sep 4, 2015 08:20 PM
