Not starting - 2001 XJR 4dr
Old Dec 19, 2016 | 03:42 PM
jwalte02's Avatar
Question Not starting - 2001 XJR 4dr
Hi everyone
Looking for a little feedback -
Wife out with the 2001 Jaguar XJR 4dr Supercharged V8, Left Hand Drive. 152K miles.
Stopped at the grocery store. Came back out within 15 minutes.The Car powered up but would not turn over. (I was not there)
Code reader revealed a P1111 - My manual states- not a critical error
She went back in the store - called me - went out to try again.. car started. I am thinking that the trans did not fully go into park....
Second item the "guide plate under the console of the shifter is loose and turning when you move the shifter into R or D.. Problem?
Thanks ... please share your thoughts
Old Dec 19, 2016 | 05:02 PM
Welcome to the forum jwalte02,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Dec 20, 2016 | 02:32 PM
yeldogt's Avatar
The car will lock out the starter as well as the transmission if it get a false reading -- there is a control under there Best to get tightened up -- you don't want to damage any of it.
