Partial load breather o-ring
Old Nov 22, 2019 | 05:36 AM
pianoman90's Avatar
Default Partial load breather o-ring
Hey, in the process of removing the valve covers, the o-ring around the partial load breather disintegrated. The hose / fitting itself is fine.
Do you all know the part number or where I can purchase a new one? After a lot of searching, I can't find any information
Here is a pic of the o-ring
Old Nov 22, 2019 | 08:21 AM
M. Stojanovic's Avatar
The circled o-ring should not be there as it does nothing (someone has added it thinking it will seal). The o-rings that seal are the ones on the pipe fitting (in-between the pliers "needles" on your pic) and they go into the fitting on the cam cover.
Old Nov 22, 2019 | 05:58 PM
pianoman90's Avatar
Interesting, I thought these came standard on the X308s. Here is another pic showing the o-ring.
Hopefully it won't matter, because I can't find a replacement anywhere!
Old Nov 22, 2019 | 09:59 PM
Just had a look at my spare cam cover - the yellow compound that looks like an o-ring is actually squeezed-out excess resin that glues the fitting to the cam cover. You can leave it as it is, partially chipped off (as on my spare cover) or you can scrape off the remaining portions for neater appearance.
Old May 3, 2021 | 04:57 AM
Jaunty's Avatar
That's the fella!
Thank you, I shall be able to find it now, and ream to 2.5mm.
Old May 3, 2021 | 12:38 PM
Vauxi's Avatar
The same seal is weeping on my engne and valve cover on that spot is always slightly messy.
vincent661983
Jun 16, 2018 12:36 PM
banar
Jun 15, 2018 08:43 PM
Dale Dunn
Oct 13, 2016 09:11 PM
Steve8
Dec 4, 2014 09:10 PM
zayne742
Apr 17, 2010 03:12 PM
