Peculiar P1646 problem
Old Mar 5, 2024 | 01:10 PM
clubairth1's Avatar
Community Influencer
Thanks much for the ending!
I had thought O2 sensor from the beginning BUT found all the conflicting info that you did.
Now the strangest thing is you posted that the car will throw the exact same code for 2 completely different reasons! That I have never seen.
Old Mar 5, 2024 | 01:28 PM
Jeroen's Avatar
Just wondering out loud; could there be a difference here between the EU and the US version? My XJR is US version.
Jeroen
Old Mar 6, 2024 | 01:05 AM
M. Stojanovic's Avatar
No difference. I posted earlier in this thread extracts for year 2001 ON for OBD2 codes (US) and for EOBD codes (EU). I have attached here all Jaguar code related documents that I have.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 6, 2024 | 07:40 AM
mayhem's Avatar
Interestingly, my 01 threw a 1646 when I bought it. Diagnosed a front right side O2 sensor, replaced it and the code persisted until I found this same info about the later AJ27 cars as is in this thread. Pulled both fuel pump relays, shunted the appropriate pins to run the pumps and verified they both were operating and then replaced the relays, code vanished and has not reappeared since, this was about 35,000 miles ago.
Old Mar 6, 2024 | 11:44 AM
Jeroen's Avatar
many thanks for posting all those documents, much appreciated!
Jeroen
Throwback
Jan 2, 2024 05:12 PM
lwz3
Jul 20, 2021 07:25 PM
beady
Feb 27, 2016 11:18 PM
gmccoy000
Oct 22, 2013 11:29 AM
