Power Steering cooler bypass
Old Oct 5, 2017 | 01:05 PM
wforslund3's Avatar
Default Power Steering cooler bypass
Just purchased a 04 XJR and so far loving much more than our 03 X type. Doing a more intense underbody inspection I found that the line from the steering box 'T' fitting that I assume went to the PS fluid cooler has been plugged. Find no evidence of the actual cooler any longer. Is it safe to be without the cooler or will it cause premature pump failure?
