Power when out while driving 1999 XJ6 VAN DE PLAS
My hubby did my brakes yesterday, changed out the brakes. I lost all power while I was driving. The car was just fine now all of a sudden I have zero power. Where can we start to figure out what happened????😲 I have a 1999 XJ6 Van de Plas
First of all, is the car an XJ8 or XJ6? There is no 1999 XJ6 so it has to be one or the other. Second, was he messing with the ABS Wheel Speed Sensor while changing the breaks? it might be triggering the Traction Control to kick in while driving? Third, any lights on the dash? does this happen at a certain speed or engine speed rpm? Are you driving aggressively at stops to trigger the ASC/Trac?
I suspect 2 things, ...a possible key module reader failure...or bad battery cable.
Does the engine turn over or are you not getting anything when inserting the key into the ignition? Do you have 2 keys and have you tried them both?
Have you checked the battery, how old is it? Is there any corrosion on it or the cables. Corrosion is a murder suspect for these cars and will kill their ability to function properly.
I have just the one key, the battery is in good condition, I get nothing when I turn the key. I do have interior lights and windows that function just fine fine, but nothing happens when I turn the key to start the car. The dash does not turn on either.
jkm210
Apr 24, 2016 04:58 AM
sunchip
Oct 27, 2013 04:25 PM
pablackcat
XJ40 ( XJ81 )
Jul 26, 2009 03:42 PM
