Proper Sealant
Old Nov 8, 2015 | 01:25 PM
bigcat777's Avatar
Default Proper Sealant
Inside the cam cover, passenger side, there is a plate (plastic type) holding the metal meshes in place. It cam e loose so I removed all the sealant, which seems like glue/foam material. Very hard, and chip it away. Now I need to replace the sealant, have no idea what to use. Subject to heat, oil of course, but I know a flexible sealant wasn't used. Any help please. Seemed to be very rigid and brown (color could be from oil) although may set differently. Would any good sealant work?
Old Nov 8, 2015 | 03:30 PM
bigcat777's Avatar
I am thinking permatex BLACK max oil resistance...does anyone think it is a BAD idea?
Old Nov 8, 2015 | 04:00 PM
RJ237's Avatar
The original is likely a hot melt adhesive, perhaps urethane. If it were mine I would probably look for a used cover first because I'm not comfortable with the Permatex.
I just don't have a better idea.
Old Nov 8, 2015 | 04:56 PM
bigcat777's Avatar
Thanks RJ- The cover I see on ebay is not as good condition as mine, well except the plate is attached. It does appear a hot melt adhesive was used, could you suggest an alternative to used covers? New ones are around $300-$400 Any other adhesives?
Old Nov 11, 2015 | 11:48 AM
bigcat777's Avatar
Decided to good go with the best quality used cover I can find. I did speak with Permatex, they said they had nothing for me to use, they admitted it is an interesting idea, a sealant/adhesive that would work in that environment. Thanks RJ
leadfoot4
Jan 1, 2024 09:17 AM
VinnyT
Jan 25, 2016 07:46 PM
SD96XJ6L
Jan 19, 2016 05:34 PM
Gpalace
Nov 4, 2015 04:12 PM
kalacho2006
Oct 21, 2015 07:06 PM
