Radio relays
Old Dec 1, 2013 | 06:58 PM
brianxj8's Avatar
Default Radio relays
Replaced the battery and now have zero power to stereo system. No fuse diagram in manual. Checked box on left front wheel well and fuse ok. Checked trunk box... Same. Help please.
Old Dec 2, 2013 | 05:11 AM
xjay8's Avatar
Brian...not sure if NA models have security code for radio....might be worth checking.
Mine being an ROW model does.
The main fuse information and what they cover should be in one of the eight vehicle hand books.
Old Dec 2, 2013 | 05:26 AM
jimbov8's Avatar
First fuse to check is F9 10A in the left hand side heel board, that supplies the unit.
Next, F9 10A in the trunk fuse box, that supplies the aerial motor.
Last, F3 5A in the trunk fuse box, that is the ignition switched supply.
US variants do not normally have a radio code so if the above doesn't solve the problem, a simple call to Jaguar with your VIN will tell you if you need one or not.
Hope this helps.
hoodun
Nov 20, 2022 02:35 PM
Paora
Feb 4, 2021 12:36 AM
philwarner
Jan 31, 2016 09:36 AM
ziondio
Sep 28, 2015 11:24 AM
