reaching secondary headlight adjusters
Brutal mentioned it once. Which post eludes me after hours of searching over the last
two days.
Each of the headlights has two adjusters. The vertical adjuster is easy to find. That is the
one most people use.
But, there is also a secondary adjuster for the horizontal adjustment which is harder to
find and reach. They are reached through the four holes in the top of the radiator support panel.
Has anyone successfully reached the secondary adjuster for the left side low beam? The
joint for the fender seems to be in the way.
The head is turned with an allen key. Does anyone know the size?
two days.
