Rear Door issue?
Old Oct 6, 2017 | 10:44 PM
coastaljag98's Avatar
Default Rear Door issue?
my drivers side rear door won’t lock or unlock with the rest nor will window roll up or down. All others work fine. Is there a fuse?
Old Oct 7, 2017 | 10:29 AM
avern1's Avatar
Does the window operate with the rear door controls? If not you might try swapping the door control module with the other rear door. If the fault moves then the module is bad. If it doesn't then the fault is probably with the Body Processor Module.
Old Oct 7, 2017 | 10:15 PM
Good idea. I’ll try that.
