Rear parcel shelf & seat adjuster
Old Oct 28, 2018 | 05:11 PM
Jagman85's Avatar
Default Rear parcel shelf & seat adjuster
Hi guys
I've tried searching for info before making a thread but come up with nothing. I want to identify what my rear parcel shelf should look like. It currently appears to be a flat, hard surface & was wondering if that's normal, since I thought carpet or something should be there.
Also the rear shelf mounted brake light, it appears that it's held up by only 2 plastic mounts glued on the rear glass. Mine have broken so I want to replace them but I have no idea how to search for them (what theyre called, or if they have a part number, etc)
One more thing to trouble you with is the plastic housing for the drivers seat adjuster button module (the part it sits in inside the seat), mine is broken & was wondering if that's something I can search specifically for online. Otherwise I'd naturally just hunt for one in a wreck.
Thanks again.
Old Oct 28, 2018 | 05:38 PM
Carnival Kid's Avatar
Jagman, sometimes small parts like the third brake light clips take some tracking down on micro-fish searches, but here is a start, a link to the third brake light
https://www.sngbarratt.com/us/#!/Eng...f-3c42ec4dbf52
And a link to the rear parcel shelf............
https://www.sngbarratt.com/us/#!/Eng...AND%20SUNBLIND
And a link to get you close to the seat switches......
https://www.sngbarratt.com/us/#!/Eng...20SWITCH-FRONT
Old Oct 28, 2018 | 05:44 PM
Jagman85's Avatar
Thank you for that
Old Oct 28, 2018 | 06:14 PM
ericjansen's Avatar
The base version was just the plain, hard plastic shelf, even my '98 Vanden Plas was just that.
More luxury versions, maybe later versions in general, had the lower part filled with wood, covered with thin foam and the cloth you will also find in the door pockets (and kind of changes to dust after 20 years under the sun).
When I received my Captains seats, I made a new base from plywood, used slightly thicker foam, then covered it with leather in the same color as the interior.
Although maybe a detail, I love the look and feel of it now.
silverR
Nov 7, 2015 01:06 PM
powerhouse
Jul 24, 2015 05:29 PM
H20boy
Oct 29, 2012 10:26 PM
budsang1
Nov 7, 2009 05:25 PM
