Recurring Old Problem (Shifter) and a New One (Stereo Noise)
Old May 30, 2008 | 03:20 PM
inertian's Avatar
Default Recurring Old Problem (Shifter) and a New One (Stereo Noise)
Recurring Old Problem:
Every so often my '98 VDP (125K miles) won't shift into Park. Its fine for a while, then it happens three or four times in a row, usually at inopportune times like when I'm handing the car off for a wash. If I run through the gears in the J-Gate a few times, or drive forward and reverse a bit, it usually resolves itself. Any ideas?
New Problem:
Just last week, I started hearing electrical interference type noises through the stereo (radio or CD), that varied in pitch and volume with the speed of the engine (in any gear). If I shut off the radio, it goes away for a while, then sometimes comes back, sometimes not. I have the 6-CD changer in the trunk, standard HK sound system.
Thanks!
Old May 31, 2008 | 09:56 AM
jag_genius's Avatar
Default RE: Recurring Old Problem (Shifter) and a New One (Stereo Noise)
sounds like you may have a shifter cable problem.. and i wud disconnect your cd player and if the noise comes back then you may need a head unit..
JarodL
Mar 7, 2024 01:39 AM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
AL NZ
Sep 4, 2015 08:39 PM
